Currently reading:
shower fitted by friend
Discuss shower fitted by friend in the UK Electrical Forum area at ElectriciansForums.net
Baker1988
hi all just a quick question my girlfriend dad has just had a shower fitted cos his old one has broke (just a like for like)it was just a friend of his who did it for him dont think he is a spark just had some experiance i have checked it at the request of my girlfriend as she does not trust her dads friend it all seems fine there is not test sheets with it so i did a few tests zs and ir and all seems fine the only problem i have got is that the board has no rcd it is a old board but not really old it has mcbs and even a few rcbos buti told him he should really have a rcd on the shower circuit but i would probily be easier to get a rcbo for the circuit but he does not want to shell out the £27 for it so my girlfriend said she will buy it if i think it needs it just so he is safe so what do you all think does it need one i think it does but thought i would ask you lot first
Taken from the ESC FAQ page.....
"Q2.10If I replace an existing electric shower, do I now have to provide RCD protection for it?
No, unless RCD protection is required by the manufacturer’s installation instructions, or a new circuit is required (to provide for increased load, for example).
Regulation number(s)
  • 134.1.1
  • 510.3"
I'd still fit an RCBO (double pole) or a stand alone rcd, we all would.
My moneys in the instructions for the replacement shower insisting an RCD is fitted.
Therefore.....even though its a replacement, an RCD is now required. Because thats what it says in the book of the one you are fitting!
I'd take swicades tack. Sort it out yourself & reap the (eh hem) reward.
As mentioned will be a pig to get the 10mm in the Rcbo reliably, always is a game.
Took two hours doing an isolator (ceiling) once. Fitted like a glove and was a work of art (was a good paying job!). Better than ramming it up desperately screwing it all together, only to hear the sickening crunch & crack of a shattering patress.....arrrggghh
A couple of points.
When replacing items of equipment, it does not have to be on a like for like basis for it not to be notifiable.
As such you can replace an 8.5kW shower with a 10.5kW shower as long as the wiring is appropriately sized for the load.
You can also replace CPDs higher or lower rated, or even of a differnt type without notification.
It's when the wiring is altered that it becomes notifiable.
Reply to shower fitted by friend in the UK Electrical Forum area at ElectriciansForums.net
