S
spurs1980
Went to job today lady said when the heating had been on for a few hours the ring main tripped taking the rcd with it the boiler is on a separate mcb any ideas
Maybe it has nothing to do with the boiler?Went to job today lady said when the heating had been on for a few hours the ring main tripped taking the rcd with it the boiler is on a separate mcb any ideas
Testing is all very well if you can assure all is disconnected , but you can get readings from elements ,motors etc , which can be misleadingFirst thing to learn is NEVER trust the ocupier... Second thing is Trust the test gear. Third thing,,, and the most important and this is where most go wrong................. Get the Test gear out the van,It wont bite,, unless its on IR at 500 + then its amusing, But it will help you more than the ocupier....
