J
Jackall
Hello.
I'd be interested in what people think of the following, and any helpful advice.
I want to put a washing-machine in a bathroom and here are the relevant details :
The machine is rated IPX4, power rated at 1850W, has instructions as to how to remove the plug if required, and the manual doesn't say anything about not putting it into a bathroom.
It will be going into an airing cupboard which is totally enclosed, and will be 1.1m from the edge of the bath - so, outside the Zones but within the 3m restriction on socket outlets.
The airing cupboard has the cold water pipe needed for the plumbing and is next to a basin, to which I will be connecting the drainage hose. The cupboard also has a small radiator at the back, which I will need to raise up to accommodate the washing machine.
It also has two switched fused connection units : one for the shaver/light, and one for the hot-air heater (max. 2kW). As far as I can tell, these are currently the only outlets on that particular circuit, which is protected by a 15amp wired fuse. There are three fuse-boxes in the house, all of them with wire fuses.
So, is it doable ? There is nowhere else to put the washer so hopefully it is, but here is what I'm planning :
I don't think there will be any problems with the plumbing but I'm not sure about the electrics! The circuit would seem to need a higher rated fuse (30amp) if the heater and washing machine were used at the same time but I can't see that happening and might even remove the heater, especially if it's necessary to be able to get the washing machine connected. Would it be possible to just change the current 15amp fuse to a 30amp one? I've also noticed that the actual fuse already there is in upside-down in the box but can't see how that matters...?
Also, because there is no RCD protection anywhere within the electricity supply, I was thinking of using an RCD protected Switched Fused Connection Unit with flex outlet, wired in to one of the other FCDs already in the airing cupboard.
Anyway, I have two choices : If people here think the above is OK, I will get in touch with the LABC and take it from there; but if you think it sounds a bit tricky or dodgy, I will get in touch with a local electrician. I would like to have a go at it myself, though. Although I have City and Guilds Certificates in plumbing and electrics, I don't have a Part P qualification, but I have done a lot of the training (especially on testing and the effects on other parts of the Building Regs, etc.) and do have The Electrician's Guide and the 7671 17th Wiring Regs. Therefore, this would be good experience for me, especially as I hope to do more such work as a self-employed handyman.
Maybe you're all going to warn me off this and suggest I try a different career (!) but I would be grateful for any feedback.
Thanks.
Thanks.
