G
guest119
Cold. Good point about it being hot because the customer stated it tripped after it had been used for a while.
Dohhh! :icon10:
Boydy
I suspected you wouldn't be able to, personally I don't like holding my finger on them when MCBs pop, makes me jump when your not expecting it.
safe isolation?
Oh God this is getting a little Embarrassing now, surely UK sparks knew that and was just pulling your leg, dear God surely.
Surely you have switched a breaker on and its popped? You know, when someone rings you and says the breaker wont go on, so you go and have a look and switch it and it flicks off... Doesn't require safe isolation. I suppose the bit about not expecting it was not the right word.
- - - Updated - - -
Yes I did know that, I have a way of using incorrect terminology some times!
Thank god thats that worry over with then lol
Eh?...
hmm...Post 12 about the elastic band was a joke....
whats this 2395?I don't have the 2391 but have got the 2394 and passed that first time and am doing my 2395 next month.
Ill be honest though I did think the 2394 was pretty easy and can't see what the fuss is. I hear the 95 is a little more tricky but will see what happens.
so..is this 2395 the replacement for the 2391?I'm guessing that was said with an element of sarcasm maybe as you would know the answer.
2394 is inspection and testing
2395 is period inspection and testing
i still did the online exam and got 98% in that and did the written exam.
Not quite. Because the 'modern' electrician isnt as highly trained as the 'older' generation electrician (and being a politically correct society in which no-one fails) they split the 2391 into two to make it easier to pass.
2394 is the hold your hand thro' having a quick looksie at the electrics and 2395 is letting you do a little bit on your own.
Though of course I could be totally wrong ........
so..one is the 2392...and the other is the 2391?
Apparently it's been made easier to pass...
thats what i was looking for...i just wanted to know which numbers had replaced what...Your wrong, 2392 is so easy it's pointless even doing it.
2394 and 2395 are the two bits of the 2391.
2394 is initial verification inspection and testing only. Closed book written exam and online multi choice, plus practical involving full initial verification on two boards, three phase and a single phase, motor starters etc and carious other things. Plus there's more practical bits you do too.
2395 is périodicité inspecition and testing only. And there's a written exam and multi choice too.
you cannot do a 2391 now so the only option is 2394 and 2395, both if which you can have standalone but to make it the equivalent if the old 2391 you need to have done both.
if its essentially the same qual..then i dont see the point...its upto Damian mind you what he does....Mr Skelton's done both (2391 and the new pair) and said on another thread that he thought the new pair were harder.
2394 is initial verification inspection and testing only. Closed book written exam and online multi choice .....
i think he said theres some kind of written one as well...but is it open or closed book?What! They're giving you the answers to choose from ..... dont tell me one is highlighted in bold incase you arent sure!!
This is a wind up I bet your sitting there giggling. yes 94 and 95 both have a closed book written exam
so the 2394 is a written exam with open bookNo that's not right.
each qualification be it 2394 or 2495 had a practical, multiple choice and a closed book written exam
so you covered non-conducting locations then.Oh Im done with this thread! I bet your in stitches rolling round in the floor!
