safe isolation?
Surely you have switched a breaker on and its popped? You know, when someone rings you and says the breaker wont go on, so you go and have a look and switch it and it flicks off... Doesn't require safe isolation. I suppose the bit about not expecting it was not the right word.
- - - Updated - - -
Oh God this is getting a little Embarrassing now, surely UK sparks knew that and was just pulling your leg, dear God surely.
Yes I did know that, I have a way of using incorrect terminology some times!
- - - Updated - - -
then this would have answered your post at #12
see...i was right...you were wrong...
glad thats cleared up:p
I don't have the 2391 but have got the 2394 and passed that first time and am doing my 2395 next month.
Ill be honest though I did think the 2394 was pretty easy and can't see what the fuss is. I hear the 95 is a little more tricky but will see what happens.
whats this 2395?
is that the theory bit?
Post 12 about the elastic band was a joke....
Oh, was it. I better take that elastic band out of my tool box then. :-)
Reactions: 2 people
I'm guessing that was said with an element of sarcasm maybe as you would know the answer.
2394 is inspection and testing
2395 is period inspection and testing
i still did the online exam and got 98% in that and did the written exam.
so..is this 2395 the replacement for the 2391?
no really...
when i did it ...it was the 2391...split into a practical..and a written assessment closed book....
Not quite. Because the 'modern' electrician isnt as highly trained as the 'older' generation electrician (and being a politically correct society in which no-one fails) they split the 2391 into two to make it easier to pass.
2394 is the hold your hand thro' having a quick looksie at the electrics and 2395 is letting you do a little bit on your own.
Though of course I could be totally wrong ........
so..one is the 2392...and the other is the 2391?
Nope, the old 2392 (fundemental insp & testing) has disappeared and become part of 2394 -- hence a holding your hand qualification!
And the old 2391-20 (design and verification) which was a L3 qual is now replaced with a new L4 qual for the same theory. So in line with improving educational standards the 'newer' electrician can claim hes at L4 standard for designing whilst the old sweats are only L3 for the same.
Do you think Im becoming a cynical old git?
Reactions: 2 people
Possible Job For Tomorrow
Andrewr3,
Badged01,
