T
toptrics
Hi all
In order to measure your pefc pscc, you need to test across all 3 line conductors then multiply by 2 record the highest value, this is correct isnt it.
Hi all
The PSCC will be the highest in a three phase installation. Double the highest line to neutral value if your equipment cannot measure between phases.
Hi all
Each line conductor separately the same method and connections as if you were doing it on single phase, take the highest of the 3 readings, and as you say double it. Job done.
Actually, I read that the reason for the x 2 is to allow for the remote possibility of a fault across all three phases, which is closer to 2x PFC of one phase to N or E, than 1.732 x
if I remember correctly it was Geoff Cronshaw on the IET forum. I may be mistaken, but I'm sure I'm not.
Reactions: 2 people
whats 0.268 between friends ? ;-)
its enough to blow your face off whatever the final figure lol.
Reactions: 1 person
you're still too cryptic to give me a fighting chance.
just freakin tell me or we'll be here all night lol.
Lightweight!
Blame QI for this...RIZLA are actually RIZ made by LA+ :-)
Arg...no more, keep looking behind you.... :-)
and Riz being the french for rice and La+ originating from Lacroix.
thought you were going to challenge me there.
archy caught with pants down ;-)
i'm too fast old man. :-D
is there ones called JOB as well from france?
3 phase pfc
toptrics,
grantr37,
