Search the forum,
Discuss Problem with light switch. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
Recently my light for the upstairs stopped working. So I replaced the bulb, now it is working but now the switch is making some noise and the light dimms sometimes!
Can anyone tell me the reason for this and how to fix it?
Many Thanks
i would check for a loose connection in the switch and or the light it self
Tight connections are the best and if in doubt get a sparky out
Loose connections can cause a fire
recently my light for the upstairs stopped working. So i replaced the bulb, now it is working but now the switch is making some noise and the light dimms sometimes!
Many thanks
hi
most probably you have loose conn. Somewhere.
Check the switch line conn.or the celing rose wires.
or a dodgy switch. replace switch and make sure all connections are good.
Yer this has gota be a loose conection or high resistance across the switch. replace the noisy switch. or you could tell the switch to quieten down as its causing a nucience :)
With out being rude.........
Turn off light circuit at consumer unit
use screwdriver to turn screw clockwise to tighten all screws in light and light switch (please note only do this if you have some experience)
If in doubt get an electrician out, spending money is better then getting a shock to shorten your life
Can I use the fused electrical screw driver to test if the light circuit is live after turning off the circuit breaker at consumer unit?
Can u describe how it is done? Do we make contact with the fused screw driver on the switch line in the ceiling rose, and contact with line in the switch ?
Many thanks
Reply to Problem with light switch. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
