Discuss Adding a new light with a switch in the UK Electrical Forum area at ElectriciansForums.net
I’m looking to add a new light and with a switch to a old property with older wiring techniques I have not come across.
From looking the cables are going to the switch first rather than the light . Any help is appreciated
Same question last month.
Same photos
All you need is a T&E from the switch, up to the new light position. Youve got the neutral there. Also, any new work needs to be protected by RCD.
Advise you get an electrician though... as the old cables may not be in great condition to be working on.
Same photos
Ok thanks for reply.so a twin and earth from the switch to the new light but I want the new light with its own switch . So a cable from the the new light to the new switch?
They are there, you can make out the solid green sleeving shoved into the wall cavity and bodged tigether in a connector block.
yes. i see it now.
Not on the 3 core though.
Anyway... As youve got a Live, Neutral and Earth at this switch... you can either take a T&E to another switch, then up to the light.... or to the light first, then down to the switch.
There's earths there, what's missing is a back-box for the switch!
There's only just about a wall there to add a box to....!
I think the first task there is cutting back the plaster and laths back to the next stud, fitting a noggin to sit a box on, adding some new laths, and having some fun with plaster....
Reply to Adding a new light with a switch in the UK Electrical Forum area at ElectriciansForums.net
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
