- Dec 18, 2011
- 5,379
- 6,731
- 405,788
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hello all..
I have read some of the threads on the 'adiabatic equation' and still cannot understand it!
I have my assessor turning up on thursday to view my CU change, I have gone through everything with a fine tooth comb and am trying to cover everything he may find fault with. My ring main is 2.5mm[SUP]2 [/SUP]with a 1mm[SUP]2 [/SUP]cpc. OSG states min cpc should be 1.5mm[SUP]2 [/SUP]for a MCB 32A with less than 3kA PFC, but BS7671 says I can use the adiabatic equation.
The ring is on a 32A mcb. The PFC is 1.61kA.
I can see the adiabatic equation, but I'm not sure how to use it. Is I = PFC? How do I determine the operating time of my NHXB32 wylex MCB? Do I use 115 as my value for K?
I've looked at a couple of my neighbours houses and they both have 1mm[SUP]2 [/SUP]cpc on the ring (built in the 80's) so I'm assuming this must be ok, but I would like to give the assessor a proper answer if he spots this rather than just 'all the other houses have it and, from what I've read on the internet it seems ok'.
Thanks..
Thanks..
