Discuss Anyone fancy a bit of domestic fault finding? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Yes this is for a house!
Whatever kind of house has this kind of configuration in? Is it a large mansion?
There's 72 breakers if you include the 3 phase ones as 3 MCB's ........................
Its not huge ......... 6 or 7 bedrooms, indoor pool, stables, kennels (the latter both run off SP distribution circuits from here)
Talk about splitting the house into many circuits, which is rather pointless with a single up front RCD ......................
I'm interested to know what purpose it all serves and what each bit is for, my curiosity has been piqued!
Indeed, quite a bit packed in there.
I'd be guessing several sets of outside lights on 24h timers or PE cells.
Contactor/TOL sets on the RHS I'd say for irrigation, pool system, bore pump maybe.
Various sets of heating for floors or different areas.
Personally I'd have put all the extra bits in a proper control board in a services room, but you work with what you have.
Reply to Anyone fancy a bit of domestic fault finding? in the UK Electrical Forum area at ElectriciansForums.net
I have recently taken on a lecture role at a local college. Their facilities are in ---- state. My aim to rebuild/build a comprehensive fault...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi all, Gone to look at a intermittent ground floor sockets fault today, the RCBO was tripping at random times with no pattern. Nailed down a...
Hi I'm trying to find if I have a fault in these to brakers of in the lines. The 32A braker leads as far as I know only to a junction box that use...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
