Discuss Cable tray supports needed in the Electrical Tools and Products area at ElectriciansForums.net
Pat H
I'm looking at fitting some cable trays in a domestic loft.
I need them to sit 150mm above the current ceiling joists running across those joists.
I'm struggling to find and tray supports that stand up from a wooden joist. Plenty of options to hang trays but that's not practical.
Any ideas?
I could get a chippy to make me wooden stand off but if I ca get buy something it's easier.
Most of the hangers can also be screwed down onto timber, just use them upside down?
I could do that but they don't offer much side to side support. The whole tray could move sidewsrds and collapse. But I could sort that with 2 diagonal supports.
I'd need a C shaped one or my tray will end up vertical rather than flat.
I would just make up some timber supports , I keep 4 x 2 in my garage for situations where I need to knock up some frame or supports
Thanks. Yes that's the simple solution.
4 x 2 timbers is cheapest and easiest option. or even rescue a pallet from a skip. break up and use. cross braces as and when needed.
Use uni strut with zebs and gutter bolts. If tightened adequately shouldn’t slide off, or use 2 smaller bits of uni strut to make a 90 degree either end to stop this happening.
Reply to Cable tray supports needed in the Electrical Tools and Products area at ElectriciansForums.net
Hi All, I'm planning to install a 300mm cable tray underneath a false floor for a 95mm SWA supply cable. The issue is the tiles underneath the...
I’m in the process of changing my old downlights in the bathroom , I put them in years ago with advice from my late father who was a sparky, these...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
