H
HarryB1987
Hi
I'm in the process of changing my MR16 bulbs to LEDs. I've manged to cut out most of the transformers and wire in a at GU10 lamp fitting which has worked fine.
However I have run into a little problem. I have pulled down a couple of transformers which appear to have to have 2 main cables running into them (2 Neutral & 2 Live) . It appears one of the cables is looped to the rest of the spotlights in the room. Previously i have only encountered 1 cable running into the transformer, which i have then cut out and wired in the GU10 lamp.
I guess my question is how can i connect the loop and the bulb together as they all previously ran through the transformer?
I have included pictures.
Many thanks,
Harry
Many thanks,
Harry
