- Aug 30, 2011
- 641
- 492
- 137,226
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Electrical Engineer (Qualified)
I usually code no spd with no code or a C3.
However I have been sent to check compliance with BS 7671 on some new builds, there is no SPD present.
We usually say the date installed does not make a difference to coding but it does in a way.
The same may apply if Arc Fault Detection Device not installed in high rise flats or care homes.
- TL;DR
- Spd eicr code
