Discuss Drilling joists vertically in the UK Electrical Forum area at ElectriciansForums.net
I don’t know if you would be able to help me. I want to drill 2 x 25mm and a 20mm hole through these joists to get into the loft.
Is drilling vertically through joists allowed? It’s a bungalow so there’s only the loft above but the only info I can find is about drilling horizontally rather than drilling inside a cavity wall up into the loft. Is there anywhere that advises on such things?
thank you if you can help
There are called 'top plates' or 'head plate' and are not joists.
Not sure about the rules of drilling through these... I'm presuming it's allowed but I think there may be something that states what max size hole you can drill in a certain size of plate.
What is the width of the plate? The face that has '825' on it...
Guidance for that sort of thing is probably in Approved Document A - one of the documents that is actually available free of charge online to anyone...
But as mentioned this isn't a joist, so there should be no problem drilling through it - though it appears to be double thickness so you'll need a fairly good bit and drill
With joists the usual rule is a hole no more than 0.25 x the depth of the joist, between 0.25 and 0.4 of the length of the span, but for some reason this doesn't seem to apply to plumbers :rolleyes:
If it's wiring that's going up, you should probably keep the holes as near the centre line as possible, to ensure the cables are as far as possible away from the stud wall either side. Looking at it they will be less than 50mm from the wall in any case, so will need RCD protection if they aren't already.
Look to the right in the photo
Yep, but we don't know the hole size, that is why I questioned the dimension of the plate.
I wouldn't want someone drilling two 25mm holes through both plates and only leaving 3mm of wood either side.
Experience has taught me that the further back you go the more likely you are to snooker yourself with whatever construction is above it (especially if it's an exterior wall and the roof plate is nearby) - so I quite often just 'half drill' a hole in the side, more of a notch, so that you can find the cable above OK.
Go through the existing hole. If you are running cables up there they would need to comply with safe zone requirements. i.e. you cant just put them in the middle of the wall unless there are accessories going on the new wall.
Just thinking about that, if you were to drill exactly in the centre of a 100mm studwork top timber you'd achieve 50mm clearance on both sides within reason once the plasterboard was fixed. I've only ever treated wiring in solid walls which is never far below the surface as the real intention behind safe zones. But having said that you can generally get a socket/switch or even consumer unit in alignment with the hole/s.
It's not a problem to drill that, and as you have a pull-cord switch there already, that will be easy to identify from above, so easy to measure from that, to the left, and avoid any joist above. Use a pilot drill before attacking it with a spade/forstner/holesaw...easy does it!
Reply to Drilling joists vertically in the UK Electrical Forum area at ElectriciansForums.net
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Hi all, my name is Pete and I’m new to this site. Could anyone clarify the following question for me please. Does BS7671 cover rules on...
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
