Discuss earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So if using an EL clamp to calculate IR you would be calculating the impedance as the insulation has a capacitive reactance..
Insulation impedance (including capacitive reactance that could raise current ,but not power consumption... Hence appearing a little lower Z than actual R.
Was hoping for some amazing science ,(but with only the current -It cannot know the phase of the voltage to {filter-out} capacitive part of current )
Not to matter.
Reply to earth leakage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all Suggestions please. I’m working on a 3 phase shop install with a bunch of typical circuits. As each cct is energised the earth leakage...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
I WAS ONCE SHOWN HOW TO CALCULATE INSULATION RESISTANCE USING A CLAMP METER. SO I NEED HELP AS IVE FORGOTTEN. CAN ANYONE HELP WITH THIS FOLLOWING...
