Discuss Harmonic current / distortion in the UK Electrical Forum area at ElectriciansForums.net
Jay 1987
Trainee
Hi guys I have a question, when we consider the assessment of general characteristics for any installation, who Measures /considers/ enquires about harmonics.
is that the job of a normal Installation spark ? If it’s not who does it and how do they test for it?
if it is the job of the normal spark what does it entail ?
It would normally be considered at a design stage. For domestic installations no special precautions are needed because most of the heavy loads are usually heating elements which, as true resistances, do not create harmonic currents. The contribution of any distorting loads (e.g. phase-angle controlled dimmers, half-wave rectified electronics etc) is small. Industrial installations might include large loads with specific characteristics that have a significant impact on the overall installation, such as rectified inputs to VFDs that do not have PFC. These would be known in advance and designed for, and in certain cases, loads that could disrupt the power quality for other customers would have to be agreed in advance with the supplier.
From the wiring point of view, a distorted waveform on a single-phase circuit is not going to cause any problems provided Ib<In<Iz as both conductors are protected by the OCPD. On 3-phase installations with zero-sequence harmonic loads (e.g. the 3rd harmonic component of a phase-angle controlled load), the neutral current can exceed any one line current therefore the OCPD may not protect an equal-sized neutral and an increased conductor may be required (or, a reduced conductor might not be acceptable).
Reply to Harmonic current / distortion in the UK Electrical Forum area at ElectriciansForums.net
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
10K
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
