Discuss Help with a fault question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
So for college I'm having to fill out a job form and answer questions on a job I've done, for this form it's TESTING.
As I'm a lowly data apprentice Doing an electrical apprenticeship I'm not too sure on some things
So the fault I've decided to write about is one time where I had a full lighting panel (control4) with 8 control packs with 8 circuits each, each pack had it's own 6a mcb and were all on a single 32a RCD, whenever you flicked the rcd it tripped instantly, now I know this is due to the small amount of earth leakage each pack and quickly we changed to RCBOs , the only thing is the question asks "What tests did you perform" and I'm stumped, I can just say "I just knew it was earth leakage"
I would appreciate any help
@Pete999 I agree, but depends on what he has done . And by the time he fills those forms and tested the circuits it would be as prudent to issue an EIC in my opinion .
Edit . Last paragraph.
This was a real installation as I read it , not a mock up , so I would expect it was more than minor works.
Like I said Ruston I agree with your answer,just making the OP aware of what 7671 says about circuit alterations, swapping all those CBs for RCBOs is more. than Minor works, as it's a college type exorcise you never know what the examination body requires.
Reply to Help with a fault question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
I saw a Fluke 1653B on Gumtree local to me being sold as faulty. Fault was stated as no continuity between 'N' and 'PE' ports on the resistance...
Hi, I'm back in the electrical game after 9 years break so feeling a little rusty! I'm adding an additional socket to a circuit but the main RCD...
Electrical Courses
