Discuss How many points? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mickys86
If a circuit has two lights, which incorporates two switches, how many points do you put down?
I always thought it was 4 but my colleague today told me it was two because you only have two lights.
don't matter anymore my new installation certs has nowhere to list how many points/lights there are on each circuit.
in any avent the answer is 2
2 points as in no. of points served on a schedule of test results, but 4 points when you are pricing an install at price per point.
i would, but some would class them as 2.
This one always seems to cause confusion with apprentices and novices. A double (or even a triple) socket outlet is only ONE point of utilisation. Similarly if you have chandelier with 20 lamps it's still only ONE point of utilisation.
mickey do you price per point on your re wires been asked to do one for a friend not done them for a couple of years trying to stay away from them but used to charge 40 pound per point that is switches spurs spots skts etc
45-50 per point is about normal these days. but more for cookers /showers etc. all depends on the accessories as well. if cust. wants metal accs. then obviously allow for extra cost.
Reply to How many points? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
