Discuss Lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
411.3.4 Within domestic premises additional protection by RCD not exceeding 30mA shall be provided for AC final circuits supplying luminaires.
Not the exact wording but near enough.
I agree with you. But what about industrial and comercial premises ?
There is no blanket statement like domestic for commercial and industrial lighting circuits however the installation method of the circuit may result in the requirement.
This would be down to the installation method and if there's any requirements for compliance with certain areas of Part 7.
Generally additional protection would not be required however if you had a workshop with showers then you would need additional protection for the circuits supplying, or passing through, the location containing a bath or shower as an example.
If lighting circuit is all surface, pvc conduit/pvc trunking/ surface/ clipped direct .
IMO that would omit the rcd requirement.
Tin hat on , good debate eh. (new installs)
Reply to Lighting circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
I have a lighting circuit cable (1mm) powering a telescope (12 volts) in an observatory total draw 84 watts drawn from a transformer. There is a 6...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
