Discuss Lighting fault query in the UK Electrical Forum area at ElectriciansForums.net
Was fitting 2 lights today that had been taken down by someone start of the year so the ceiling could be painted. Cables at light switch were marked L and SW so straight away I was thinking that’s no right. Thought id double check I was getting a neutral at light, was getting 24V between live and sw at light (neutral). Opened the switch and the cables were disconnected, but the one marked common was dead, checked all the fuses in the lighting board and all of the cables going away were live. Any ideas other than possible break in cable at some point baring in mind it’s VIRs, was late in the day and have to go back to it. Not the most experienced at fault finding but so just looking for a bit of advice
I would not have touched it with a long
Barge pole, OK some peaple on here might say has long it passes the IR testing, so no earth there L-N so what was the fitting 1or 2.
Am I missing your point as I would take that to mean Live (live all the time) and Switched Live (going to light)
That could be induced voltage on the 'floating' switch wire
VIR - all bets are now off I'm afraid.
Do you have a permanent live at the fitting?
Some photos would help, but I'd be very very wary of re-energising VIR.
So basically 2 cables at the light were in block, one marked L and one marked SW. so straight away I was thinking why is that SW and not Neutral, so checked to see if I was getting a neutral at light. Turned on switch and nothin happened at the light, opened up the switch and the cables weren’t connected. I then tested these cables and was getting 12V at the switch between Live and earth. Was getting 24v between the 2 cables at the light constantly
The best way Is get a piece of scrap paper and work out what goes were. So that we can see how it is.
Reply to Lighting fault query in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
