Discuss long runs 1.5mm to 1.0mm in the Electricians' Talk area at ElectriciansForums.net
Hi all,
got some sockets and lights to do in a hall, 25mtrs to first switch/socket and then various LED lights
would it be best to run from the mains to the switches in 1.5 and then all round to the lights in 1.0mm long runs to lights and hate terminating in 1.5
cheers
Grand
Hi all,
cheers
Grand
For Domestic i would run 1.5 to the switches and 1mm to the lights, i doubt voltdrop will be an issue. What about the sockests 2.5/4mm?
Cheers
again is a commercial building small kitchen big halls, not alot of loading or insulation to worry about just longish runs, probably keep the 4.0mm to 4.0mm as there aint mush in it really
cheers
Grand
must be a windup, the vd calc is so simple and in the osg gives you all the info you need
there isnt a lot if loading in my kitchen, only 9 led spots (used to be 50watt gu10's)
i have put 50+ in one house before no problem
Reply to long runs 1.5mm to 1.0mm in the Electricians' Talk area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
