Welcome to the forum.
You have a heavy demand on that trailer for a standard electricity supply for a mobile unit, your maximum utilisation is about 60A.
Most mobile supplies tend to be 16A with a few 32A if you are lucky and you will need a fairly reasonable generator to provide that level of power.
I would suggest that the unit would need to be operated on a very conservative basis and due account taken of what is connected and switched on at any one time.
In practice the majority of operators assume infinite power at all times and take no consideration of possible overloads.
Because once in use the equipment will be going on and off on temperature, this does allow you some leeway but in general I would tend to try and arrange switching such that large demand items cannot be on simultaneously. Switching on would need to be staged to avoid a heavy overload initially.
Once all is in use then you should be able to operate on a 32A supply so long as due care is taken to limit heater use, e.g. rice warmers may not need to be on all the time once they are hot and could be switched off for a while if the lids are remaining in place at slow times or is it possible to use only one rice warmer depending on customer demand.
Running on a 16A supply would mean a limitation on what could be operated at once and so a cooking plan would need to be in place for these occasions.
Really you are trying to look at running only two or three of the high power kit at any one time.
