P
Piratepete
Hi Guys and Dolls
In my 2004 edition of the IEE Inspection and Testing Guidance Note 3, page 78, Protective conductor continuity can be confirmed with an Earth fault loop impedence test (R1 + R2 or R2 is not required to be measured). (Note 4)
Ring circuit continuity also does not have to be measured 'Where there are proper records of previous tests and no changes have been made to the ring final circuit'
Is this still allowable under the latest regime for PIRs?
If so, do you rely on a Zs test only?
Pete :winkiss:
Pete :winkiss:
