Discuss Rcd selection in the UK Electrical Forum area at ElectriciansForums.net
Dm7192
I am rewiring a 2 bedroom outhouse which I've been made aware will include a supply to a shed.
I'm told the shed will we used as a work shop using equipment such as rotary grinders, motors, welding equipment and other power tools.
I know welding equipment can produces supply distortion's a I.e. harmonics and motors have high inertia currents therefore I am protecting this circuit with a type D breaker however I am unsure as to what sort of characteristics my Rcd should have to deal with this load type, should I use one with a delayed trip facility or possibly 100mA trip tolerance?
Any help on this is greatly appreciated thanks
An ordinary 30mA RCD of appropriate current rating should be just fine. If it's typical 'small workshop' equipment in good condition you won't have a problem. Consider splitting the loads over more than one RCD if there's going to be more than one item of equipment in use at any one time.
Reply to Rcd selection in the UK Electrical Forum area at ElectriciansForums.net
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
