Discuss rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It's a good shout e54 I was also shown to test at socket outlets but was aware the gn3 says at device and I've had my 2391 since 1998 so I have tested both ways over the years so surely the trip times would be quicker at the device will retest at device
In his defence he is actually a good teacher and a lot better than most at the college. I think if you asked a lot of electricians they would test at the circuit outlets
No matter how good you are, you'll never know everything. Always learning.....
It would be even better, for both you and the rest of this lecturers students, if what he was teaching was correct and to BS7671 guidelines....
was back on site today e54 you couldnt possibly get your test probes on to these dorman smith rcbos so the test would have to be done at socket outlets but on your domestic dual rcd boards you could just test at the device thanks
If the test meters probes don't/can't reach the terminals, because of deep tunnels then connect a short length of cable (6'' or so) and test from these short tails. In fact some manufacturers actually recommend this approach to testing there RCD devices.... I personally don't like D. Smith MCB/RCBOs, and never have!!! lol!!
Reply to rcd testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
I will start with apologies, as I have not thought this through very much (at all) yet and have just sat down with a beer.... meaning I thought...
Investigating for remedial works, 2 identical but separate installations (MK Dual RCD 4+4 consumer units with 60898/B MCB's) CU 1 RCD1 x1...
