masteramish
- Reaction score
- 1
Hello Guys
Hope you are all keeping well and safe in this unprecedented times.
Just wanted some advise please. So Yesterday i had a new radiator installed but the installation required extending pipe work under the stairs near the consumer unit and where the main electric feed into the house is. These are white plastic pipes where a T was taken from an existing radiator and passing nice and neatly under the consumer unit.
Now the pipe which has been extended under the stairs is fairly close at the closest point where it passes the main black electric cable coming into the house. The distance from the consumer unit is approx 15cms but the closest point between the white pipe and black MAIN cable is approx 3 cms. Now the gas safe installer (he was very good) who installed this advised this is very common and said if its gas pipes their needs to be minimum 15CMs from the consumer unit and 2.5CMS from the plug sockets but for water pipe their is no law as such but the electrical guideline is a minimum 2.5 CMS (25 MM) between the mains cable and the central heating pipe. In my case it is 3CM. He assured me this is ok as he advised their just need to be a sensible distance to allow for condensation etc. So he says as long as the distance is a minimum of 2.5CMS we will be ok.
At the time i took his word for it but now i just want to be 100 percent sure if this still passes the guideline if in future i wanted to get an electric safety certificate or do i need to go down the route of moving pipes or the consumer unit. I had a quick search online but couldn't find anything definitive on this.
I have attached a couple of pics below. Cant exactly tell from the pic but where the black mains cable coming into the house is going under the carpet is around 3CMS from the white pipe. I have circled this in red. Just wanted to know if the below installation will pass the British electric regulations for future reference.
Any advise would be appreciated
Thank you all
Thank you all
