A
AbneyTeal
Hi, I'm in the process improving our recently bought 1930's 3 bed house. The loft has been completely cleared out to spray woodworm treatment, but before the insulation back goes down, I thought this would be a good time to rewire the upstairs lighting. I should point out I'm only a DIY'er, but a very careful one! Currently the electrics in the loft consist of 1 junction box with all the light and switch cables coming out from it. I thought I could replicate the current layout using 1.5mm twin and earth cable, replacing the old red/black cabling. Would it be ok to use this layout?
In addition to this, all the walls in the house are brick & plaster with the cables placed in steel conduit. I was thinking of fitting the new cables down the old conduit to the switches as its only a short distance, they should go down it fine. In the loft, the conduit terminates level with the top of the joists with the cable looking vulnerable to damage. Would cutting these level with the laths & removing the burr with a file make more sense? Would like to also replace the switch back boxes as the current ones are an older style with the thread at the back, they're a pain to screw into.
I used to do plastering many years back, so any damage in that department can be easily rectified. We plan to get a spark in eventually to change the consumer unit as it looks a bit old (80's, 90's), also to check the electrics in the rest of the house. At the moment I just need to get my loft insulation back down!
