Discuss Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
Ran a security light off a fluresent light in kitchen.
Used 4 port supply push in wire connecter.
Earth and neutral wires connected inline to existing terminal blocks.
When I turn "OFF" bathroom fluresent light after use, the security light turns on.
What's causing this please?
Thanks!!
Neutral being switched on the floro.
Do you have a two probe voltage test device (eg a multimeter).?
show us pics of the connections you have made at the new light and the kitchen light.
Yes I do have a two probe multimeter.
Did you mean to say supply came from kitchen and turning off bathroom causes security light to come on?
Supply cable I assume comes from "bathroom too kitchen" as its closest to Consumer Unit.
Yes at night turning off bathroom switch causes Security Light to come on for the set period.
Does the security light operate normally when the bathroom light is on?
Does it operate normally when the bathroom light is off?
I'd be checking the terminals at the bathroom light switch anyhow, doubt that's the problem though
Is this a 3-plate arrangement with supplies at the lights and twins dropped to switches
On a different tack - might the security light be seeing light emanating from the bathroom?
It's presumably supposed to respond to IR from a person, and/or movement, but if it was detecting 'dusk' when the bathroom light goes off, might that switch it on?
Masking the detector should show one way or the other ?
The light is outside my kitchen door overlooking back garden.
Bathroom is some distance away.
Thanks for reply!
Is everything back fully functional
Prob a simple answer I guess
It looks like the chassis tag on the fluorescent is no longer connected to the terminal block ?
In the absence of many obvious answer
If everything is in order with the installation wiring and the new pir light wiring
I would be checking the switch terminals and probably checking if the issue occurs with an incandescent bulb connected at the bathroom
Seen something strange happen before switching off fluorescents
More than likely the answer is more obvious than that though
Reply to Security Light Problem. in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
