G
Griz80
Hi guys
I have connected 8 x 250 watt 35 v solar panels in series to connect to an enfinity 2kw inverter. The open voltage I get from the array at the dc isolator is 220vdc or so, but when testing at the dc inverter terminals I am only getting around 68vdc. I have had the inverter (enfinity) given to me and because of the under voltage it will not fire up.
Any Ideas?
Thanks in advance
Inverter creating a volt drop?
Reactions: Specialist
Checked all connections and polarity on dc sidemail. Think it is a faulty inverter. Thanks for the help guys
Solar Array confusion
Griz80,
Griz80,
