Discuss Solar Array confusion in the UK Electrical Forum area at ElectriciansForums.net
G
Griz80
Hi guys
I have connected 8 x 250 watt 35 v solar panels in series to connect to an enfinity 2kw inverter. The open voltage I get from the array at the dc isolator is 220vdc or so, but when testing at the dc inverter terminals I am only getting around 68vdc. I have had the inverter (enfinity) given to me and because of the under voltage it will not fire up.
Any Ideas?
Thanks in advance
Reply to Solar Array confusion in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi my name is Gintas I connected solar hybrid inverter to my house ring supply and it work very well everything except the gas boiler for on...
