R
rhys24
Hi
Been working through a few options with an electrician, on how to get an 4 way db to supply some new equipment being installed.
Due to the original board being pretty full up, they don't want to split a henley block out of it. As its only 100amp board and pretty loaded up already.
So suggested this.
Run from where the mains come into the property 25mm 3 core onto the new 4 way board with 100a switch. Due to the location of this its going to need about 40-50 meters of cable and I know its not cheap!
That was the first options, upon discussing with a few other people suggested this:-
Just splitting the power before the distribution board in the property then running to the new db and the old board. Would this be any difference?
As I guess the breaker in the ryefield box would be 100 amps?
The other challenge, is that the main fuse for the property as its a london apartment is locked up in ryefield box which is locked. What's the correct way to get access to this box? It has an edf sticker on it.
Any suggestions would be great!
So suggested this.
