S
Squid
Terminate to isolator box/switch then cable to CSU phone insurers and make sure the shed is covered.
Discuss Terminate SWA in Wiska or straight to Garage CU in the UK Electrical Forum area at ElectriciansForums.net
I wasn’t unhappy with any response.
My question was specifically relating to the connection to the CU from outside.
Others asked more questions of me that don’t affect whether I go through the floor or through an external box. In answering those questions I expose my lack of knowledge and terminology.
And which point the thread goes off topic.
For what it’s worth. I have had a sparks round about this job but as I say it’s not what I was asking.
I completely understand.It's not that simple with electrics and people of the public requesting info. We have to look at all the factors when giving out info. You should be able to understand this.
Just don’t see how saying seek an electrician is a response.
That is my opinion.
That’s better. Not so generic.To do what you propose involves a lot more than the questions you are asking. It is not off topic to include a reasoned judgement regards your own safety as that is intrinsic to being able to give you advice in a safe manner. I am concerned you probably will not do dead tests prior to commissioning the circuit and live test once you have. Do not expect anyone will compromise that by encouraging you to install in a dangerous way. When it is said get an electrician it is because you have made it abundantly clear you are dangerous to yourself and maybe more importantly, others.
That’s fair enough. It’s just nice to know why that’s all. Who knows someone might learn something.It's usually the best and most relevant response with regards to safety, which is what being an electrician is all about.
To be fair there is too much information required to do what you require , cable sizing , cable protection , earthing arrangements and a whole lot more. To say you need an electrician is a fact, not an unfair comment.
If you have 5 weeks to spare then you can get fully conversant with it all and ride off into the sunset with a part p logo stuck to your saddle
I asked what is best from the point of connecting to the garage from the SWA. That is the context.
Reply to Terminate SWA in Wiska or straight to Garage CU in the UK Electrical Forum area at ElectriciansForums.net
