A
andypo
Hi,
I am replacing an old double oven with 2 new small ovens. The old oven is wired into a dedicated supply with a switch and the consumer board has a 32amp MCB B breaker.
New oven 1 requires a 15 amp fuse and 2790W. link below.
www.zanussi.co.uk
New oven 2 requires a 16 amp fuse and 2790W. link below.
www.zanussi.co.uk
Can the existing 32amp MCB B supply be repurposed for the 2 new ovens by connecting a 42amp dual connection plate to the existing switch?
Thanks.
Series 20 FanCook Integrated Oven Electric Oven | Zanussi
The Series 20 FanCook Oven circulates hot air heat with its fan and ring element. Air is continuously moved around in the oven cavity, to make sure that dishes can be cooked on different level at the same time
Built-in & Integrated Kitchen Appliances | Zanussi
Clever design - the ultimate way to save space! Explore Zanussi's compact built in range of ovens and microwaves for your kitchen.
Thanks.
