T
twoscoops
Hi
I feel a bit dim! The instructions to my megger 1552 seem to make things seem very simple but my results don't.
My question is what setting should I be using to test Ze should I use 'No trip' or 'Hi' .....?
The manual states that when RCD's are present then 'No Trip' should be selected but my limited knowledge states there are no RCD's on the supply externally so why use this setting..?
And what setting for PFC if I use PFC in the 'No Trip' range it simply displays Trp on testing but it tests Ok in the 'Hi' range giving a result of 13kA,
Am I missing the point can anyone explain this to me in lay mans' terms so it is clear
Thanks in advance for any help in my quandry.
