if the socket is switched on when plugging in an appliance, there may be a small spark. usually nothing wrong. best practice is to make sure the socket switch is in the off position when plugging something in, and also, when unplugging. even then you may get a spark from the switch if it's a high load appliance. if in doubt, get a local electrician in to advise.
