P
Discuss Why would you in the UK Electrical Forum area at ElectriciansForums.net
Maybe it was the only RCD protected circuit.
But why would that stop you from using it inside as well ?
If it was used for inside equipment, it may not be available for use for outside when required.
eh ?? lol , so unplug whats in it then.
May not be convenient if it was a computer, printer, or fridge, or something else with a long on time.
Perhaps the outdoor circuit that was (Or was not) protected by an RCD was on a different Phase (Line) to the indoor Line and to bring it indoors would possibly bring a cross Phase fault of 400V Line to Line ?.
J
Then why would those items be plugged into a socket that says outside use only ?
youre clutching at straws here lol.
Well you said straws ! Have a bundle lmfao !Give me a break !
;-D
You're getting confused.
If it wasn't labelled but was next to a door or window, and was the only RCD protected socket, it may get used by someone for inside equipment.
It IS labelled to stop /deter internal use, so wouldn't have anything else plugged in.
This is probably from 20 or 30 years ago
Reply to Why would you in the UK Electrical Forum area at ElectriciansForums.net
