- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- United Kingdom
- Retired Electrician
I know that there are quite a few members still fitting plastic, but I thought it might be useful to have some reviews on 3rd Amendment CU's from the different manufacturers, only time will tell I suppose.
I'll kick it off. I fitted a couple of Wylex's offerings. Not the most prettiest of things, very 80's square in a magnolia finish. Had the semi fixed bus bar which stopped the twisting of mcb's etc when tightening connections. Seemed to be more room inside, for wiring & RCBO's. The issue I found was cable entry. 32mm knock outs for tails, but only 20mm for circuits. The 20mm are so close, that enlarging them to 25mm, would prevent you from using the adjacent knock out, although you could go bigger, but just adds time to the install. Rear cable entry is not much better, with two oblong knock outs, which I jigsaw'd together, and they're offering a CU pattress to facilitate rear cable enty. Wylex at the moment aren't selling 'fully populated' models, so that puts up the price. Sort of 7/10 from me!
