Discuss Rcd or not in the UK Electrical Forum area at ElectriciansForums.net
L
Liam howe
Morning guys,
Need some quick advise without having to look through the bible to find the answer.
Installing a small 4 way unit into a domestic property to supply a new oven which requires 3 seperate supplies of 16amps.
Does the new sub board im installing need to be rcd protected or not?
Liam
are cables fed from this sub buried in walls < 50mm deep?
Im guessing it needs an RCD, but i dont like guessing hence advice. Im an industrial installer dont work on dwellings much.
The cables are buried in walls less than 50mm yes
Domestic Installer Commercial Installer now an Industrial Installer, that's a DI,CI and II, what next?
Im asking for advice not your cocky remarks. Ive just started out on my own and now having to think for myself.
I dont know every page of the regs yet like you oldies and i havent got time to check them.
No theres no RCD protection in the property at all.
When you say three separate supplies of 16a are you meaning a three phase cooker or three part cooker? Sorry it thats a dumb question. RCD are required for all sockets in domestic, period. It also applies to industrial, commercial. It stipulates RCD for cables in walls, portable equipment for use outside and sockets generally. I would say that putting an RCD as additional protection is not a bad thing, however the regs don't stipulate that for a cooker unless the switch has a socket in it. Look at 411.3.3
No not three phase. All single phase seperate supplies. Doing this as there different parts of the cooker and if theres a problem with say the warmingg tray thats in the oven if that doesnt work atleast the other parts will. No sockets on the oven supplies at all just hard wired.
you could of course use one of the other methods of protection stated in 522.6.101. eg. use SWA.
Hi my friend,i would urge you to edit that,you will get a more cordial response :)
I suspect that post was aimed at me, although I could be wrong,
I suspect that post was aimed at me, although I may be wrong, Liam you are a practicing Electrician, charging people for the work you do, to say you don't have time to check makes me shudder, and believe it or not, I don't know everything, nor can I navigate , BS 7671 very quickly with remarks like this one, you may find people unwilling to help.
Its wasnt aimed at any one person, im looking for a quick bit of advice. Navigating around the regs book can be time consuming and im am very busy right now, i thought thats what these forums were for, i must be mistaken.
These forums are for advice.
However, we are all busy too. An as stated you are an "Industrial electrician" you must have been working to the regs for some time now. An knowing where RCD protection is required is one of the more basic requirements.
If you look through, the reg number required has already been given.
Posts like this worry me. You are presumably charging the customer for this job but you openly state that you don't know the requirements for RCD protection and that you don't have time to look at the regs for them. Something is very wrong here.
Also, your atttitude to people is downright rude - how you expect to get any help when you post like this is beyond me also.
Daz
Most equipment these days in a domestic property in the Uk will run on an RCD unit, unless the manufacture says in the instruction manual not to install on an RCD, if they do then you will have to think about how you install cables to the isolator without the need for RCD protection.
if in doubt install with an RCD main switch & if all ok leave it.
Hi @Liam howe , can we not write abrassive comments like this, doing so will bring you to the attention of ourselves (Staff), I have read through the thread I cannot see any reason why you felt such a response was warranted, if I have missed something than please enlighten me otherwise refrain from such an attitude.
I see you have come on the forum looking for help but expressed a 'cannot be bothered' attitude to looking such info up in the reg's, the fact members have even bothered to help you here given your approach is very good of them.
Your regulations should be your bible and having the attitude that its some sort of inconvenience is a tad worrying in all honesty. I will, like the majority of members on here agree that the regulations can be confusing and sometimes seem contradictary and that's where we can help out as a forum but we expect you to put the effort in too to benefit from the help our members offer, we hope you take this into account before you post any future threads, your background in industrial should be to your advantage as this usually requires better knowledge of the BS7671 than simply doing only domestic, the same regulations and rules found in the industrial and commercial scene are the same regs that are used in domestic too.
PS .. For future reference, if you feel any member has posted something you find offensive or abusive then please hit the report button at the bottom of their post, we will then review the report and deal with it accordingly, don't take it up on yourself to respond in a similar manner as the staff usually end up wasting our valuable time editing and deleting posts and handing out infractions or worse.
Regards, Darkwood
Regards, Darkwood
THANKS
Shame there isn't a thanks button any more.....
Reply to Rcd or not in the UK Electrical Forum area at ElectriciansForums.net
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi there , Currently doing a college project where i need to select protective devices for the contract. I'm now at the point of selecting SPDs...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
