T
Toneyz
What are you doing/done today ? not a direct poll but I thought that it would be interesting to see a snapshot of a day in the life of a E.F. member did it go to plan what problems did you overcome.
Discuss What are you doing/done today in the UK Electrical Forum area at ElectriciansForums.net
Yesterday, spent most of the day in a hot dusty, itchy loft, altering extractor fan (previously diy installed), replacing old down lights and switching in a bathroom. Got wet feet, 'cos I had to park me van in a puddle on the drive
Today I'm going back there to make good a tiny hole made by a moving plasterboard nail, they found in an adjoining bedroom and a smudge on the ceiling in the bathroom. Apparently, the homeowner nearly cried.
I love my job
Oh hoping mine turn up todayTyping up the EICR I did yesterday and the accompanying invoice and quote for remedials. Off to see a potential customer at 11am and then producing the quote for that. Pop to Asda to pick up some batteries so I can try out my latest purchases from the toolbox of @Pete999
Oooh and unboxing my CK Dextro VDE Slim screwdrivers which arrived yesterday. Thank you very much @CK Tools . They look lurvely
I would hazard a guess that Land N are different types of cable could be wrong thoughJust finished testing this flat in an 18 story redevelopment less than a year old all okay apart from one thing can you spot it.View attachment 36539
who cares?Is it the fact the breakers don't run in order of size from the RCD? Largest next to the RCD
who cares?
Who Cares Winswho cares?
2 rcds 1 neutral barJust finished testing this flat in an 18 story redevelopment less than a year old all okay apart from one thing can you spot it.View attachment 36539
2nd N bar on a hager is to the left of the earth bar, out of shot in pic. good try though.2 rcds 1 neutral bar
EICR install pre Amd3plastic CU?
Old Boy? watch it MateyIt was one thing old boy used to nag about, I always thought it was good practice
It isn't a metal board was only done in November.I would hazard a guess that Land N are different types of cable could be wrong though
Have you quoted the wrong post Westy? or is that the answer?It isn't a metal board was only done in November.
Plastic dbJust finished testing this flat in an 18 story redevelopment less than a year old all okay apart from one thing can you spot it.View attachment 36539
so i was right then?It isn't a metal board was only done in November.
not impressed with the slim screwdrivers from c.k.Typing up the EICR I did yesterday and the accompanying invoice and quote for remedials. Off to see a potential customer at 11am and then producing the quote for that. Pop to Asda to pick up some batteries so I can try out my latest purchases from the toolbox of @Pete999
i've got wiha slims. they are extremely robust. in 3 years i've onlybroke 1 tip and that was my own fault for trying to undo a pozi.2 with a 4mm flat.not impressed with the slim screwdrivers from c.k.
Because there are so slim there only any good for light works I feel.
Feels like the ends will snap when tightening terminals and you can't get the grip/ torque.
I got them just to use for testing so there was n my test bag.
I use wera laser tip for installs.i've got wiha slims. they are extremely robust. in 3 years i've onlybroke 1 tip and that was my own fault for trying to undo a pozi.2 with a 4mm flat.
Best set I had, sadly gone to a new ownerI use wera laser tip for installs.
Love them
my set is pre handle storage. bits are longer and they don't supply any more as they won't go in the stupid handles of the new-fangled things. progres??? progress my ARSE.
perfect for termimals in intruder alarms untill the started using these stupid +/- things.I also love using this for terminals and testingView attachment 36544
That question should be between you and tel pete as us young uns have no idea what your on about?Anyone remember those small terminal drivers with the Bakelite handles?
yep. i'll remember the name in a bit.Anyone remember those small terminal drivers with the Bakelite handles?
like this:That question should be between you and tel pete as us young uns have no idea what your on about?
Is that tested to 1000 volts then? Haha
Bl888y Kids should be seen and not heard, only kiddingThat question should be between you and tel pete as us young uns have no idea what your on about?
Before the onset of heatshrink tubing, they don't know they are born.what's wrong with shoving a bit of sleeving on the blade? that's what the wimps did back in the 70's.
A bit like these but shorterAnyone remember those small terminal drivers with the Bakelite handles?
Reply to What are you doing/done today in the UK Electrical Forum area at ElectriciansForums.net
