Discuss LED Worklight Rechargeable in the Electrical Tools and Products area at ElectriciansForums.net
V
Vitesse
As the title says I am looking for one that will last more than a couple of hours. I have one that I bought from Screwfix a couple of years ago but it's battery life is only a couple of hours. It's the yellow one that sits on two little horizontal feet about 6 inches long.
Always use it for doing board changes in dark areas under the stairs etc... or when the power is off and I am up in a loft.
It nearly always gives me a heart attack when I am working on a CU and I am suddenly plunged into darkness, initially thinking it's something I have done on the CU and forgetting I am relying on the worklight!
Best off looking at different reviews on Amazon for the different types available. I guess the more you spend initially the better and longer lasting.
Every tool in this trade is an investment and you don't make investments to lose out!
I am a Bosch professional man!
Like the idea of the swap out battery except - you'd have to have some premonition when in a loft to think of taking that spare battery with you BUT I like the idea. Now, which button do I press for Amazon!
Yeah I had a quick look earlier but you get your average DIY'er reviews, which in the real world when you are using them on a day to day basis are pretty irrelevant. Thought I would ask the fellow sparks for their experiences?
I would probably have a head torch with me as well but we all know what's it like in the burning inferno of a loft with your head torch acting as a sweat band
I've been wearing a hard hat on site all day for 5 days a week and my leather sweat band now has a hint of cider vinegar (trouble is I like the smell but feign complaining about it - I was the kid in school that constantly smelt his watch strap!) anyhoooo! I was going to shelve out on an LED Lenser head torch 'cause I wanted one but ended up buying two Aldi camping head torches for £2.49 each including batteries. I'll have t'other one one day.
I bought the LED lenser and paid silly money for it after my old one I bought of eBay for a fiver gave up the ghost. It's another heart attack job, you are working away and all off a sudden it switches to some lower lumen mode and everything starts to go dim.
I found another one, same make as my original one, on EBay for £5.95 from China. Didn't realise at the time it didn't have batteries in it but as it was the same make the original batteries fitted. Had it for over a year and still waiting for it to burst into flames on my head! But if it does at least I will be able to see what I am doing still.
You'll going to get that risk whatever you use standard batteries or any rechargeable battery ,the work light is not going to take a lot of current so even a 3Ah battery should last a good amount of time.
What about getting a small silent generator, having no power is a pain in the butt! Enough to power lights and recharge or power some 240v tools. I think this is the way i will be going in the near future.
I know that it will not be for every situation but as posted on here before and what we used to do is have a garage C.U. with rcbo's with a double socket on a wooden board 16mm tails into supply.
I have Makita LED Torch. When Battery is close to dead it turns off, but turning it back on gives you a good 5-10 mins more time
I love my LED Lenser headtorch. It gives me a flashy warning when the battery is on its way out, then I can dial it down to low so it uses about 10% of full power and gives you a few minutes to extract yourself from wherever you are.
I also have a Milwaukee LED standing torch that uses my tool batteries. I would say that a 3Ah will probably only use a quarter of a battery being left on all day so no chance of getting caught out.
You need to get in the habit of when a battery goes flat you put it on charge.
Reply to LED Worklight Rechargeable in the Electrical Tools and Products area at ElectriciansForums.net
The stately home I work with has asked me to repair a couple floodlights not working. Mounted very high up… I could hang over the roof and checked...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
I am currently making a scaled model display that uses 16 LED in a series and I would like to wire it up to be on one switch, so I need a single...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
