Discuss Wiring of Smart Light Switch Question in the DIY Electrical Advice area at ElectriciansForums.net
Hi,
I'm attempting to wire a new Smart Wifi Light Switch (Sonoff Touch) into the living room instead of a single switch currently.
The Sonoff Touch Smart switch requires a neutral wire, which I have in my newbuild home.
The neutral I have though is two wires, both currently connected together in an terminal connector
The existing wiring is:
2 x Brown wires in Comm
1 x Black wire in L1
In the back of the Sonoff Touch Light Switch I have "Nin" "Lin" and "Lout"
I think L1 goes to Live Out and Common goes to Live In
Do both Neutral go into "Nin"? One of the neutral wires has a bit of heatshrink on which on some Youtube video's they stated to wrap brown electrical tape around the switched cable, so is this a switched neutral if there is such a thing?
Thank you for any responses!
by looks of it the switch you have require a N- however best to read man.Ins
from your pics i think you have it almost correct. put the 2 blue (neutrals, blue and grey sleeved) into Nin. you only sleeve blues if they are switch L's , so in your case, not. the 2 browns appear to be a L loop, so these both go in Lin, and the sw/L (black sleeved) into Lout.
Thank you for your help, Successfully installed & still alive.
I just wanted some reassurance before proceeding which you did.
Reply to Wiring of Smart Light Switch Question in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
