- Feb 6, 2012
- 11,120
- 8,513
- 165,788
- United Kingdom
- Heavily Qualified Electrician / Teacher / Tutor - etc
considering he put it in then a EICR is in order not a EIC.The customer said "Should I call him back to put it right?"
I said you should only call him back to give him a slapand would not want this guy touching any electric ever again.
I have given the customer a quote to redo the consumer unit again
your customer needs to speak to local b/c. before work is carried out .
