Discuss Shed to shed which cable? in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I hope you're all keeping well. I'd like to replace the electrical cable which runs overhead for three metres between my two sheds, what type of cable should I use?
without any more info from the OP, then I'm with @bigspark17 post #3.
I’m wondering whether the existing cable has deteriorated because of UV, whether it’s been driven into, or perhaps the missus keeps on using it as a clothes line?
If you use bell wired then this will help with the drying of the clothes...
Why do you want to replace the cable?
Well, someone used a length of 2.5mm twin core and earth cable in a hosepipe buried 2 inches below ground and yesterday my wife thinking it was a tree root cut through it with a pair of loppers.
Reply to Shed to shed which cable? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, just a quick one on an earthing arrangement for a radial circuit on a wooden workshop I have just had installed. I have run a 3 core 2.5mm...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi, I rent a house and need a cable to my shed and unfortunately the LL dosent want anything dug into his lawn ! Before I get an electrician in i...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
I would like to run power to a shed that is 40m from my other shed which is powered by a 10mm cable from the house. I have access to a 100m roll...
