Lister1987
Trainee
May 16, 2019
2,040
1,703
2,688
38
Warrington
Trainee Electrician
Business Name
PNX ELECTRICAL
I'm in the unlucky position of having issues with my teeth causing agonising pain but being unable to have anything done about it without IV sedation.
I've tried getting hold of emergency dentists but no luck at all and even when I do speak with them they can't do a damn thing; they explain what they would normally do; root canal, extractions and the like but I simply can't have work done while I'm conscious; it would not be safe for them more than anything - Extremely aggressive needle phobia, coupled with extremely pathetic pain threshold - You can understand why sedation is needed, for me and them.
I've had x-rays and a plan of action previously agreed (sedation referral) but now COVID has hit I can't get anything done (apparently missed the referral window but had zero contact from them), in the meanwhile I'm here in agony, did not sleep at all last night due to the pain, taken all manor of painkillers, stopping just shy of morphine.
I'm going to try again in the morning but over the feeling I'm stuck with this until COVID is over. I'm at my witts end and my poor partner and kids are in the firing line....
I suffered with a severe phobia of dentists for many years, to the point that I would get so worked up the local anaesthetic didn't work.
Hypnotherapy sorted it to the point I almost fall asleep in the chair.
If you've got issues that are causing pain as you describe, it should be considered urgent work which has not been suspended.
  • Informative
Reactions: DPG and westward10
I feel ya pain @Lister1987 id rather have a punch in the nose than toothache! Just to lighten the mood.....my sister has a needle phobia to the point she instantly passes out when she sees one.....so she lays in the chair dentist gets the needle out she passes out job done ?......on a serious note though this definitely falls under emergency work especially considering your other ongoing illness mate, keep on at them I’m sure you will get treatment you need ?
If you are in a lot of pain and they have suggested root canal treatment or extraction it is possible your tooth has died and formed an abscess. If this is the case you must seek treatment as an abscess can be a highly dangerous situation and you may need antibiotics. Up until a few years ago I was like you terrified of dentists until I changed my dentist who understood my fear and things are now much better.
  • Informative
I just don’t like people poking around in my mouth. Needles are fine, regular blood donor.
I think it was when one dentist said I drank too much, that caused an aversion to even going.... I stopped seeing dentists for about 6 years.
I now go every 6 months, and touch wood, nothing serious.
I would think your situation should be essential work.
I had a filling last week and the dentist said they would carry on until told otherwise but if stopped he said they will be staffed for emergencies only.
For what it is worth, I had an abcess a few weeks ago. Likewise it was very painful. As is usual in our household we resorted in the first instance to home remedies. Which consist of two things. One is dental tincture, or clove oil the other is hydrogen peroxide. Hydrogen peroxide is a very powerful anti bacterial and can be purchased at your chemist. It should be diluted as per instructions on the bottle for mouth rinse. Clove oil is at once disinfectant and anaesthetic. It is also possible to clamp down on a clove between the teeth. Of course I did attend a dentist asap, and tooth extraction proceeded. However the pain in the first instance was at least ameliorated until I could get an appointment. Clove oil should only be applied to the area of infection and avoid getting on the gum if possible. I hope that is of some value to you.
I never suffer with abcees I must be a lucky one the odd filling now and again. Maybe I have sweet tooth . so I dent put my head under the pillow just in case the tooth fairy's rip my vangs out. Lol.
tooth fairy is away at her sister's, the seal fairy. she on furlough due to lack of work.
Not withstanding your phobia, I had an abscess on a rear molar tooth, that antibiotics couldn’t help.
Bit apprehensive, but had tooth out with just local. Popped out like pea from a pod.
I feel for you Lister...
I've had a tooth clinging on against all odds for 2 years now, causing no pain but really due to be removed.
When did it start to cause problems? 4 days ago, just after my dentist closed down his practice, of course.
As Vortigern said, hydrogen peroxide seems to be a good palliative measure, and available from your local chemist.
My personal method for relief is 3-fold
1. Rinse with hot, salty water, as warm as you can and plenty of salt.
2. Spray with Corsodyl, also available from the chemist (easier to use than hydrogen peroxide)
3. Ibuprofen
I have got great relief from the above measures, lasting most of the day, repeated before bed in the hope of getting a good night's sleep.
I must stress, I am not qualified in any way on medical or dental matters, but my dentist friends have all told me that if this works for me then it's ok.
However, I use Ibuprofen because it is an anti-inflammatory, in hope of reducing the swelling. It seems to work well for me. ..BUT there is stuff on the internet about not using it for relief of pain in a coronavirus situation because it lowers the body's immune system, which is why paracetamol is recommended instead.
I am in isolation, have no symptoms, so feel it's fine for me, and the relief is so welcome that I am happy to take whatever small risk there may be.
As also said before, your situation IS essential treatment. Here in my area I would go to the Dental Hospital and bang on the door. Do you have a local hospital with dental facilities? Or can you find one and travel?
Good luck.
My misses works in administration in NHS, also working with dental services.
She‘s told me off before now for commenting on her behalf on here.
However she says, OUR local dental services are still running urgent dental work, but not through private practices.
Not withstanding you had treatment planned through your local practice, you should ring them and follow their recorded measures for urgent treatment or check through your Trusts web site. They should have provision for a clinic that caters for persons with special needs or vulnerable persons during this current crisis.
Reactions: pirate
Tried 111, they can't help as I'm registered with a dentist, called the dentist and got automated we are closed messaging, 111 advised to call back at 0800 tomorrow but can't advise if any practices with sedation will be open - No point getting an appointment if I can't be sedated, it would not be safe for either party and the slot could go to someone more in need, not saying I'm not but I know there will be others put there in worse state than me that could be worked on...
We'll see what Tommorrow brings...
you could ask the wifey to get the frying pan out if you want to be sedated.lol.
  • Funny
Reactions: DPG and Baddegg
Or give me the frying pan... and I'll have a go ! Just trying to be helpful in these difficult times...
but would the sedation be from a hit with the pan or his wife's cooking? :p :p :p
She is still working in Ireland, and we are in total lockdown, your not allowed to leave 2km from your home
what about pre dentist days .where they tied a piece of string round tooth ,tied other end to door knob, and guess what ???????????/ yep slammed door shut:coldsweat::coldsweat::coldsweat::coldsweat::coldsweat::coldsweat::coldsweat:
Update:
Phoned my dentist last night
He came round this morning and jagged me with anaesthetic and pulled the offending tooth out
3 large gins later and I'm feeling no pain
He wore a mask, obviously i couldn't! Total time within 2 metres was less than a minute, so risk at a minimum...
I am fortunate that he is a friend, and clearly a good one...
Reactions: DPG and static zap
Lister1987
Trainee
Warrington
Trainee Electrician
Business Name
PNX ELECTRICAL
Dental work and COVID #whine
Electrician Talk
Lister1987,
telectrix,
