Discuss Can i feed an 100 amp sub panel from a 100amp main panel in the UK Electrical Forum area at ElectriciansForums.net
I currently have a 100 amp service that feeds a 100 amp main panel. That then feeds a 75 amp sub panel in the old shop. Then that 75 amp panel feeds the new shop with a 40 amp panel. What I would like to do is get a 100 amp panel in the new shop and get rid of the 75 amp panel in the old shop and hook them circuits to the main in the house + then have room for new circuits that are needed to finish the basement. looking for ideas and thoughts.
That would be a great idea. Remember that your shop is required to be GFCI protected. Good luck
Reply to Can i feed an 100 amp sub panel from a 100amp main panel in the UK Electrical Forum area at ElectriciansForums.net
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
