Ive redrawn your circuit, to make it clear (for me).
This is not actually simulating anything, I use it just for drawing (and clarifying).
I think I get you now, thank you for it !!!
Vcc at 5V and 0V go to pins 14 and 7 respectively - but you knew that - just wanted to be careful.
If you make a test rig with a known frequency crystal you could check it is working if you have a radio with a short wave band by tuning in to the weak signal from the circuit. I think short wave/HF is something like 3-30MHz if I remember well.
Reactions: _q12x_
See if you can find something that will register a 100MHz and can split from that down. I mean with discrete components. If its too much, I'll understand. And remember, we are playing until something cracks. Unfortunately I am unable to read and test anything with such high fv on any of my devices I have. But you have that cool osciloscope ... mmm. My idea is simple. If we can make a circuit with discrete components that will split from 100Mhz down, we are good. Else, we will stumble over various little shi.ts like my 555 craping itself when I need him most. Haha.
+7V(Max) Vcc to pin4 and gnd to pin 11.
I don't know anything, I just look up in the datasheet.
(Sometimes) my biggest mistake is to presume, and I still have to learn to not doing it that often myself.
Mister @pc1966 and I were looking at this circuit for some time.
Flip-Flops Using Discrete Transistors:
I know it looks a bit full... I want you to try it at 100MHz and see if it can split it in half I guess, so its Q will be 50MHz. If it will do it, I will start making some of them. You are making it on breadboard, not definitive board on cardboard or fiberglass like I do it. It will really take you some minutes to check at what is the maximum fv can be used. It will be great if you have a fv variator of some kind... that will tell us the maximum range it can go.
I could make it myself but I have to make a couple of them, to really bring down the fv to my devices level that I have here. And I probably will, because it will most probably be too much for you. Will it?
Nothing American about it. Was the UK symbol as well, until a meaningless rectangular box was foisted upon us by some committee or other.
Reactions: DPG and _q12x_
Russians, man, russians ! Haha
  • Funny
It was to make it easier for pen plotters in the early days of CAD drawings I believe. Now it is slightly irrelevant.
Reactions: _q12x_
You are right and I am right! I was talking about the 14 pin dual in line pin layout which is the type I use and have sent you.
Reactions: _q12x_
Good morning signori @marconi
- I was looking only on the pdf that you post it, later I realized that you may have different package than in the datasheet and you are mentioning them. But I didnt had the chance to add more comments because the timeout for comments on this website will cut your ideas off. Its a good idea to let comments on, not everyone is english speaker and everyone makes mistakes that can be repaired, if is given the chance, im speaking to this website managers/designers.
- It appears all my initiative with reading a 20MHz Before the IC's arrival fail. Because, it appears, the discrete components circuit has some limitations from its RC in there, and the 555 is not up to that fv, and I need a much higher fv than 20 anyway, at least 100MHz to have a normal range of testing these osc's. What matters is that we tried, we moved fast enough and we got results. In part2, we will use your IC's. Im curious if they will raise the the task, until the actual fv counter arrives. Another against time run. I am particularly against making anything against time and in rush !! I like it slow and precise. But this is a strange coincidence how everything falls this way. And the time is not that fast anyway, so about 1 week for an experiment is plenty for me anyway.
Im curious if they will raise the the task, until the actual fv counter arrives. ???
q12x : Since you mentioned the problems caused by resistance and capacitance in integrated circuits operating at high frequencies or switching speeds I thought you might enjoy reading this article:
In processors and graphics cards, what limits your clock speed? - https://techunwrapped.com/in-processors-and-graphics-cards-what-limits-your-clock-speed/
Another limit is temperature rise of the ic. Because many yet small capacitors are being charged and discharged very frequently/at a high rate - Giga Hertz in some devices - there is a significant heating effect caused by the many but small currents moving the electrons in and out of the capacitors. You know that when a current flows through resistance there is heating which causes ics like processors to warm up. So they are fitted with heat sinks and fan blows across them otherwise they would overheat and burn out. Thus, keeping the ventilation holes of your computer unobstructed is a good idea. (In the computers I worked on in the 80s with many microprocessors the air was cooled first by passing over fins cooled by chilled water at 5C.)
Reactions: _q12x_ and pc1966
I tried a quick SPICE simulation and (a) it did not work properly (toggled only first time) and (b) even then you are looking at switching times of around 10us, placing the max speed at below 50kHz even if it had worked as hoped!
Reactions: _q12x_ and marconi
Here is a 74HCT73 dual jk flip flop in cascaded toggle mode with first ff being clocked at 20MHz and scope showing 2Q output of second ff. thus divide by 4 to five 5MHz😀 I do not have any HCT93s to hand.
  • IMG_0710.mp4
    10.7 MB
Reactions: pc1966 and _q12x_
Im curious if they will raise to the task, until the actual fv counter arrives. See? Small shht like this I am not allow to repair in my previous postings because this website is made against user !
q12x : Since you mentioned the problems caused by resistance and capacitance in integrated circuits operating at high frequencies or switching speeds I thought you might enjoy reading this article: In processors and graphics cards, what limits your clock speed? - https://techunwrapped.com/in-processors-and-graphics-cards-what-limits-your-clock-speed/
And I did enjoy it. I do like MCU's, and I only worked with PIC's so far, and very limited range and very few applications I used them. I didn't go nuts with them as I wished when I discovered them in my youth. But they remain a fascinating literature for me. So the RC problem in CPU's, conform to your article, is due to the micro-wiring length and thickness, remaining constant over time while the transistors got smaller. If I understood it correctly. Very interesting. Yes. Actually mister @pc1966 spotted that RC problem in the last FF (flipflop) circuit and I concluded on his finding.
I admit, I didnt got this interested like you did about the internals of a CPU. Very nice explanation ! I like it. As a fact, everyone got amused when coming into my room and seeing my desktop PC case with one side open all the time and an external black fan blowing into it (actually towards my 2HDD), and they asked me "is it broken?" and I respond, "no, it is properly cooled". I got into this arrangement from my very first computers and it stay with me until today. I also highly recommend it. The downside it is getting dusty, quite quickly, so 1/year I do a total cleanup, I take out the processor, re-paste it, clean everything from dust, especially its heat sink radiator, that usually develops a fur on it, like a little rat.
By the way, signiori @marconi you worked in computers in the 80's you said, what did you do? Also tell me your expertise, what you did and know the best, what you master, and what you really enjoy. I realized I know nothing about you and now is a good time to ask. The same question to mister @pc1966 as well. Im equally interested.
Thank you for trying that. I am not that good in LT Spice. I have it on my pc but i cant say im good in it. Only to a point and that is a very low point.
Ahaa, an experiment, very interesting result !
See if you can obtain my results: 1/10, then 1/100, then 1/1000 divisions. As a challenge of course. Also I highly recommend to use the 555 circuit that I used. Extremely helpful but to a limit as we all know it now.
Simulations are useful but ultimately not always understood by those doing them. Generally speaking:
  • If a simulation tells you it won't work, almost certainly it won't work!
  • If a simulation tells you it will work, it might - you will need to try it to be sure.
Of course as you get to fancier tools, especially those that will extract PCB layout in to electrical parameters to replace the "wires" in the model, you get closer to reality, but often if is not practical to model everything that way.
More subtly you can get situations where you have two (or more) aspects to the circuit with very different time-constants, for example an RF transistor that can (and will) operate in the GHz region so needs pico-second time-steps to model the changing voltages & currents, and a bias control system that has millisecond time constants, so you need to run the simulation for billions of time-steps to complete it, leading to massive CPU effort and/or the simulator failing to converge normally.
Mathematicians have a term for this problem and lots of fun looking at ways of dealing with it:
And that is even before we get in to non-modelled aspects of the devices!
So a simulation is really about avoiding the alpha breadboard stage to see if it will do anything useful, thus you get to the beta stage quicker and cheaper, and then you can build your PCB or other more realistic prototype to confirm (or otherwise) that you are on the right track for success.
q12x Attached are two short clips. The first shows a divide by 10 counter with a 20 MHz input and 2 MHz output using a 74LS93 like the ones I have sent you. The second clip is this same divide by 10 counter now with its input at 5MHz taken from the output of the divide by 4 counter I made earlier using a 74LS73 - total division by 40 thus 20MHz down to 500kHz. You will be able to do the same soon. Using the 7493 you can divide by any whole number between 2 and 16. Adding 7493s so one provides the output for the next enables further division to be done as I have shown you. Hence my suggestion you build an electronic clock using a crystal as its timing source.🙂
  • IMG_0716.mp4
    16.8 MB
  • IMG_0717.mp4
    11.6 MB
q12x Attached are two short clips. The first shows a divide by 10 counter with a 20 MHz input and 2 MHz output using a 74LS93 .. The second clip ..total division by 40 thus 20MHz down to 500kHz...
to @marconi : very cool ! I like it. And thank you. But you are still limited by the maximum IC fv. Higher than its maximum and you are in the same situation as I am. Btw, what is he maximum fv it can see this 74LS93 ? Actually I will check it as well.
CP0 meaning Clock (at) Pin 0 and is an inverted CP0 with the bar on top. I wonder why 2 Clocks? Maybe because it has 2 sections? and CP1 is half speed? Hmm, very strange. So our CP0 is up to 32MHz. But if I feed him a 42Mhz crystal is dead in the bushes like my 555. But is good for all the crystals under its max value which is still good enough for me. I mentioned already, having a level of 100MHz is good because I can test all my osc's, especially those over 32MHz. But maybe 'my majority' is under 32 so everything will be good? I will see the 'majority' until after I build and test everything. What a strange project. I really didnt want to spent even 2h on it, and it turn out to spent 2 months, haha. Strange, right?
_q12x_
New York
United States of America
Make a very simple test for me
_q12x_,
_q12x_,
