Nov 23, 2022
Uk
Other
If other, please explain
Op
Business Name
N/a
Neff oven trips rcd every few weeks at about 5pm…tea time,when oven set to high temp.and temp. rising,..not sure if set temp. has been reached.
The rcd can be immediately reset and oven will stay on,..for another few weeks?
help required
We have a Neff oven which also trips the Rcd from time to time but when we turn it off after using the oven. The second you turn the dial to off , it trips the Rcd. Not every time just some times
Very odd
Where can I get a wiring diagram for neffB45E42.0GB Oven
Very odd
Not quite the same anomaly..but interesting!
Well that can be annoying, if it’s on its own RCBO, or an absolute nuisance if RCD feeding other circuits.
If that is the case, it’s maybe just close to its trip limit with other things plugged in….
An earth leakage clamp meter could measure the “normal” leakage current, and rcd ramp test to find where that RCD trips at. Says 30mA, but can be lower than that.
Uk
Other
Op
Business Name
N/a
Why does my neff oven trip every few weeks?
Jon999,
littlespark,
