- Jun 30, 2010
- 9,196
- 8,031
- 10,256,798
- United Kingdom
- Electrical Engineer (Qualified)
He said something about old being 40 and new only being 20. Both are hard wired but the position isn't changing. He said the new one would burn out due to the difference...images attached.
So the old cooker is connected to a 40A breaker and the new one only needs a 20A breaker.?? Is this correct?
I'd consider getting another electrician in to quote for the job...
Maybe there is an electrician on the forum that lives near you (High Wycombe) that could give you a quote.
