Hi could anyone point me in the right direction for the maximum permissible resistance reading for earthing rods?
Depends on the (RCD) Residual Current Device thst follows,as your unlikely to meet max ZS on mcbs alone, however the iet say above 200 ohms may not be stable, so less than 200 and as low as possible.Hi could anyone point me in the right direction for the maximum permissible resistance reading for earthing rods?
It depends very much on what RCD you are using, or even If you are using one.Hi could anyone point me in the right direction for the maximum permissible resistance reading for earthing rods?
