V
very
Hello everyone, this is my first post. I'm not an electrician, but I'm really in need of one, it seems! I have had a 4KW solar array installed to supply my home. It's ground mounted in the field next to our garden so is quite some distance from the house. The installer has put the inverter, the isolators, the generation meter etc in a wooden stable building in the field, which already had a (rarely used) electricity supply. As I understand it, the generated electricity goes back down the cabling which already existed to supply the stables and ends up in our garage where the consumer unit is. The stables circuit was wired up separately to the main consumer unit and has its own switch box thingy (is this a "sub-main"? not sure).
Anyway.
I found, as have others, that my British Gas energy monitor went nuts after the solar was switched on and the flow went bi-directional. I could no longer see my actual household consumption, only net flow without knowing the direction, and I had to use the lightbulb test, flicking a switch to work out whether I was exporting or importing. However, since I have two of these monitors, I was keen to attempt some of the solutions I found on this forum, such as using a Henley Block, or clamping around two wires at once. I printed them off and showed them to the installing electrician. Unfortunately he did not get it. At all. He got completely muddled over the whole concept and didn't seem able to implement the solutions I had printed out. He tried to put the clamps around some random cables, failed to achieve a result, and then told me "it's not a science, all this" :confused5: and gave up completely and left.
I now have no real time monitoring of either my generation or my consumption and so no way to use my electricity effectively. My installer has promised me a remote generation monitor but hasn't suggested which one yet. I've been looking at the Wattson solar plus but I'm unsure whether this can work, given the 50 metre distance between the inverter and the main consumer unit. I may be wrong, but all of the wiring diagrams seem to require them to be in closer proximity than this.
Can anyone tell me whether this is possible, please?
Failing that, is it still possible to find a monitoring solution using my two British gas energy monitors? I want to know real time electricity production and real time gross household consumption too.
I'd really appreciate any help from anyone who can shed some light on my predicament! Thank you.
Re: Is it even possible to monitor my solar pv installation properly or am I scuppere
Wattsons pretty rubbish in my experience
what inverter do you have
Can you tell us what brand and model of inverter has been fitted? How far is it from your house?
can you post a picture of the consumer unit / point where the cable feeding the stable is connected to?
yes it is possible to sort this out, it's fairly easy and I reckon most of us on here do it as standard on most jobs.
basically done like this
consumer unit
tails (1)
henley block >tails(2)>meter>tails>mini consumer unit>SWA cable>isolator(3)>inverter
tails
suppliers meter
incoming mains
(1) clamp meter to monitor consumption
(2) clamp meter to monitor generation
(3) if there are also distribution circuits for loads in the barn, then a seperate mini-consumer unit must be installed in the barn at this point to prevent potential overload of those circuits as the overload protection from the consumer unit is compromised by the PV generation input.
Thanks for the speedy responses. The inverter is a Fronius IG TL 4.0 I think. The stable is probably >50 metres from the house and garage. I can certainly take and attempt to post pics tomorrow. Am feeling a bit guilty about castigating my electrician as he was a lovely chap, but he just couldn't sort this out for me and I think he just didn't understand the problem at all, so I got frustrated.
Anyone know of a site where I can upload a couple of pics of my electrical set up?
this site. just use the attachments bit when posting, and you can upload them from your PC. need to use the go advanced button.
Ah yes. Thank you. :blush5:
OK - sounds like you've got a suitable, well-matched inverter. It will be interesting to see your snaps.
Here's the layout in the stable with the inverter etc. I'll take one of the consumer unit in the garage tomorrow and upload that.20120324_184418.jpg
oh dear!
whats happened to the proper labels, those don't comply and their should be some on the inverter and the DC cable.
Why 2 consumer units? As far as I can see the left hand one feeds the consumer marked AC isloator which then feeds a proper isolator which is rather pointless. Or has he reverse wired the one marked isolator in some sort of missguided attempt to provide RCD protection for the cable to the house? It looks like it comes from a shared RCD which is a nono. The wiring is a shambles. The supply cable to your house looks too small for a run of 50m.
check your meter is recording production as expected.
It's not looking good so far TBH
In his favour, finding an energy monitoring solution like you want thats half decent is tricky. I believe most clamp type monitors struggle with 2 way flow.
Thank you for responding, and my apologies, but the only thing I really understood from your post is "it's not looking good so far".
Yikes.
This is the same person who supplied the electrical safety certificate of course. Should I now be worried about that? Should I be getting another electrician out with better knowledge of solar array systems and wiring?
Re: the consumer units, I think the one on the left is what was already in the stable for its original electricity supply.
actually moggy, I reckon he might have got it right with the 2 garage units thing - one for solar, one for circuits in the barn, although I'm not really sure they've done it quite how we would have.
I'd have been expecting to see a reasonably hefty SWA cable somewhere though, unless the 6mm(?) t&e cable I can see is the incoming cable and it's been run through a metal pipe / conduit or something.
I think the swa is coming in from right of the DC isolator for the DC. I was wondering about the AC side, maybe, as you say, it goes into conduit of some kind. It looked to me, but may just be the way it looks, that there is a cable running from the garage unit to the consumer unit marked AC isolator. So the solar system is being run from the existing garage unit, wrongly sharing an RCD and pointlessly using 2 MCBs, migh be wrong of course. I had one like this recently but it was just to make it look smart, the cable was actually just passing through the first CU.
You can, in principle, monitor the electric generation by connecting something like an Optismart to the optical pulse read out on the PV meter. The problem will be getting that output back to a receiver if it is some distance from the house. If you are really serious you could connect an Envir monitor locally in the out building and attach a smart bridge to it. You will then need to run an ethernet cable from the bridge to a router and you can then montor usage on the web. Alternatively, mount the Envir in the outbuilding as before and buy a cheap wireless CMOS camera at Maplin. Point this at the EnviR monitor and when you want to monitor production simply view the camera using a PC.
Another approach is to buy another PV meter and install this inline with the PV feed (the Elster AC100 is cheap as chips) and then buy the EnviR montor and an optismart (£50 or so for the two units). Put both near the consumer unit in the house and the transmission range will be fine.
Measuring the incoming power is harder because the current clamps are generally hopeless. They give an indication but nothing more.
On my system I have an Oprismart/EnviR on the PV meter and this is accurate to within about 1%. I have another Optismart ion the consumer unit but it doesn't register when the system is exporting. It also wont work if your consumer unit is an older system without an optical output.
Here is a BEFORE pic of the main consumer unit in the garage, prior to the solar installationIMG_0645.JPG..and here it is after the electrician did his work:20120325_184443.jpgHope this is useful....
Your Inverter says "error" in the photo, and to be honest, and in my opinion, monitoring is the least of your problems, as pointed out by others your install does not conform.
There appears to be several things wrong, it looks like your PV system is on a shared RCD, and judging by the cable run it looks like your AC cable is too small, and the lables, (MCS do not have an approved marker pen).
I have stuck my neck out recently because of a poor install, and sadly am getting involved in another.
I am not the PV police, but this type of workmanship really rattles my cage.
I am sorry to be so blunt, if I can be of any help you are welcome to PM me,
Earthstore.
Optismart Web Page:
Current Cost - Reducing your energy bills so you can live a greener life!
"** PLEASE NOTE ** OptiSmart is not compatible with PV/micro generation.
It is vital that before purchasing any OptiSmart product you confirm it is compatible with
your meter.
- Optismarts work fine until your PV system stops generating and then the constant red light on the meter gives innacurate readings.
- Optismart meters may be ideal for PV in the future, but currently there is a fault with them when used with generation meters on PV systems.
- Current Cost are trying to resolve this problem.
- PV installers should avoid installing them until Current Cost iron out any issues with them.
are you sure you're not imagining that?
It's too blurred for me, but I can't see any message at the bottom where the fault code would be, the green light is on and there seems to be readings in all the right places for it generating ok unless I'm looking at the wrong picture or something.
Think you're looking at the wrong photo mate! Maybe at Moggy's SMA inverter pic? The OP's inverter is a Fronius and it clearly says "ERROR" on the display.
@Very: If you can get your system wired such that: the main incoming electricity feed from the grid is split by way of a junction block (Henley) - then one set of tails goes to your household consumer unit and the other set goes to all the PV install "gubbins" then your two British Gas monitors will be entirely capable of monitoring both PV generation and household consumption no problem. This is exactly how mine is set up and it's working a treat.
Is it even possible to monitor my solar pv installation properly or am I scuppered?
very,
MicraShed,
